Hi,
It seems way too easy to turn off AC output. If I do a firmware update, it turns off the AC output. If I press the AC key once with the screen off, it turns off AC output since the latest update.
If the unit runs out of charge and I start charging it seems tricky to put the AC output back on.
Just seems like AC output is a major function of using the unit as backup so it should be more difficult to 'unintentionally' turn off.
Many thanks.
