phihen Hello, After the récent update the Hub1200 no longer follows the Shelly Pro 3EM. For exemple, if I need 500w, Hub1200 will only inject 100w or 200w instead of 500w. How can I fix this?
haydar Have you considered that the regulation is very slow? It was never perfect and there is always a difference of 20-40w. Only when stabil request is there then it comes close to the requested value. Try to change the Mode and return back to ct mode again
Eric Hello avec le hub1200 il faut passer avec onpendtu on battery car le mode ct n’est pas encore stabilisé
