ich schmeiß die Antwort von Zendure mal hier rein. so soll man verfahren.
Dear customer,
To troubleshoot your Zendure AIO 2400 that is stuck in sleep mode, please follow these steps:
Disconnect and Reconnect:
Disconnect the AIO 2400 from the microinverter and solar panel.
Reconnect the solar panel while ensuring there is photovoltaic (PV) input.
Check for Charging:
Observe if the AIO 2400 can be awakened and if it begins to charge with the solar panel connected.
If the AIO 2400 powers on and starts charging, prioritize charging it before proceeding with any further operations.
Disable Energy Plan:
Connect the solar panels, turn on the AIO, and try to charge the AIO's battery with photovoltaic input.
Cancel the energy plan and set the AC output to 0W.
Battery Recovery:
When the battery recovers to the normal voltage range, the AIO will automatically exit sleep mode.
If the AIO remains in sleep mode for a long time, the battery voltage may be too low, requiring a longer time to recover from sleep mode.
Check Solar Panels:
If the AIO cannot be awakened even under good sunlight, or it cannot exit sleep mode for a long time, connect the solar panels directly to the microinverter to check if the panels are working properly.
If the solar panels are functioning normally, the issue may be due to excessive battery discharge in the AIO.
If these steps do not resolve the issue, it may be necessary to contact Zendure support for further assistance.
This response is generated by AI.
