ZenUser192A2RXK Hello, I am using homeassistant to drive the output limit. The limit is updated every 30 seconds, but i got sometimes spike of current returning in the grid . What is the maximum speed possible to update the output limit ? Thanks a lot for your help
Felli I use node red and IoBroker for this and my flow is triggered every 2 seconds. 30 seconds is far too long in my eyes, plus the latency of the Zendure device itself. Go and test around, pretty sure MQTT can do the same then the IoBroker Adapter.
TWehr with mqtt you can use 5 secondes i have 2 x hub2000 with home assistant using emqx broker and totaly disconnected from internet
