Vitalii Why never disable fans in ups mode and low ac consumer 30W even fully charged and low battery temperature? Guys, please make an update for the software because it is not possible to sleep with the device. Every night I must switch it off from the grid and every morning switch it on again
Zendure Good Morning, I'm sorry, during charging the fan will work, then could be a bit noisy. When you turn on AC Output, the SBP turns on the fan with sound. Please try, set as sleep mode in the app, then the sound will be a bit quieter.
liepinsdizains@gmail.com I have the same problem. I read that in ups mode it is not using battery anyhow if it is that then why fans are on 24/7 ? Temperature is 27-29 celsius
