Matteo while hub2000 is going in local smart ct, hub 1200 in smart ct reads a wrong measurement -12w then reads 1.4kw but does not start, (see photo) it only happens if there is also hub2000 in local smart ct if I deactivate hub2000 the other works correctly, is it a bug or a problem?
Matteo yes I know that hub1200 does not work locally in fact smart ct is via cloud but it does not work, while hub2000 with smart ct locally works very well
betty Du kannst nicht beide in ct modus betreiben, es sei den du hast die Phasen aufgeteilt, 1 auh eine Hub, 2 ,3 auf dem anderem. Ausserdem lokal und cloud ist ungünstig, weil über cloud gib es Verzögerung
Matteo yes the phases are divided into A and C and everything is correct if I restart the hub1200 then it starts working correctly again, the problem is when I activate hub2000 locally on another phase, when hub2000 went to the cloud this problem did not exist
Felli Think the problem is, that you wanna mix cloud and local. Seems that it only works via cloud, as the 1200 doesn't work local sadly. In your case, I would stay with cloud connection.
Matteo that's what I would like but hub2000 goes locally automatically, how can I choose to put it via cloud?
betty Die Lösung wäre hub2000 in ct hub1200 in intelligent Ausgleich modus : ohne Geräte mit Grundlast nach belieben
Matteo doing several tests I can confirm that the problems are when a smart ct phase goes to the cloud and the other goes to local, I'm waiting for a response from Zendure because they have made the systems unusable, or at least the possibility of choosing whether to go to the cloud or local, I would be sorry to have to buy another shelly when the pro 3em has the ability to manage 3 different phases, unless the problem is with the shelly firmware since the last update came out well before the hub2000 update with local function
betty Weiteres shelly nutzt nicht , der zegt das selbe wie der erster shelly, da kommen die Hub nur durcheinander, die Lösung ist ein Hub in ct modus der ander in andern modus zu betreiben
