ZenUser24EUU5Qb Hi All, I use my Hub2000+AB2000 in CT mode. On 4.11.2024 around 13:30 jump battery status from 58% to 100% and hub switch to bypass mode. From that time stays hub in bypass mode and will not charge and also not discharge the battery. That means today was whole day in bypass mode and battery is slowly self discharging. SOC is set to 21% and 95%. Bypass mode is set in auto mode. When was changed do disabled still the hub use bypass mode.
ZenUser24EUU5Qb Ticket created an HUB2000 was replaced by Zendure. Now with replaced hub2000 system is running without isue
