ZenUser19qp93Yy I have pvhub1200 with ab1000 and 4x210w panels. I set max output to home and output from hoymiles to 100W. But when the battery is full whole solar energy goes to the home input. If there is 300W from solar then pvhub inputs 300w to home - despite it is set to have only 100w. Max home input is respected only when the battery is able to consume the excess power i.e. 200w. Is that proper behaviour?
AixTom If the battery is full and bypass on automatic, then all solar energy goes through the home. The hub does not limit it, it even cannot do it since it bypasses the hub. So normal behavior. If you do not like it, set bypass to always off.
