Since i installed the last Master and Ac Firmware my SBV 4600 is not working properly anymore.
My Setup:
SBV 4600 connected to AC and to Solar panels on the roof
AC Output connected to the Appliances in the Basement.
So far the SBV was set to Energy saving - Energy from solar went ro the Appliances - whenever there was not enough or none available it was taken from the battery. If there was mor solar power rhan was consumed by the appliances it was used to charge the battery. In dark hours the battery was used to the set minimum discharge level and the. The SBV switched to AC.
I would live for it to go to passthrough changing when that happens instead of charging the battery for two percent then switching off AC in and discharging - then starting all over.
But it worked.
Since the last update - everytime it switches energy source it switches off AC out. Which kills my fridge an freezers and IT in the celler. It I don‘t act personally to switch it back on everything is dead.
Does anyone have the same issue? Or is there a new setting I havent found yet?
PLEASE fix that problem. Otherwise the SBV is rendered quute useless to my - once again.
Thank you.
