Eric Bonjour j’ai changé de micro onduleur par un hms1000 2T quand je rentre le serial dans opendtu il ne reconnaît pas le Hms1000 2T que dois-je faire svp merci
Eric Je ne c’est pas si c’est la dernière version je l’ai acheté il y a un mois à un vendeur en Allemagne je n’y connais rien
mash Maybe just a typo? Supported are only the prefixes 1143, 1144, 1410. Look here: https://www.opendtu.solar/hardware/inverter_overview/
mash Good, so the serial should be supported. Let's see for the version, https://www.opendtu.solar/firmware/configuration/system_info/. Btw: OpenDtu or OpenDtuOnBattery?
mash Great, so if you really have an older OpenDtuOnBattery version, here is a link to the latest one: https://github.com/hoylabs/OpenDTU-OnBattery/releases/tag/2024.10.22
mash OK, I'll try to walk you through. Let's first find out more about your system. Could please you open Info, then System and tell me Firmware Version / Git Hash and Flash Memory Size?
