Dmytro My superbase turn off AC twice after full charge. I dont know why. AC output always 20-40 W and sometimes used as USP. How can I turn on AC output for permanent work without off?
Alexjcd Same issue with 1500 model. Also SPB doesn't react at limitation for charging (80%, 90%). It always recharge till 100%
Zendure Alexjcd Morning, it is not problem, it is normal, that if you use UPS function, SOC could not be used. That is, if you set the charge limitation, e.g. 80%,90%, it will not work.
Zendure Dmytro Well, if during charging AC turns itself off, that is not normal, unplug the power cord, would AC also turn itself off? Please don't worry, you could just share your problem with us through email (support@zendure.com), better with a small video about the problem and SN number of your device. So that we can help you better there. Have a nice weekend.
