ZenUser2208qutE The app tells me I need to upgrade the firmware on the battery management system and the control chip. However there is no button to accept or to carry out the upgrade and if you just leave it sitting on that page nothing happens for I've tested it for 45 minutes. Anybody know how to get the upgrade to work?
ted lapidus Il faut cliquer sur votre hub2000 ou autre système , sur la page d'accueil. Ensuite il faut cliquer sur la roue crantée en haut à droite et aller tout en bas pour voir s'il faut faire des mises à jour.
ZenUser2208qutE Actually it took 5 hours before the system connected and allowed me to upgrade the firmware. Follow up question. Does the app have to be running (smartphone switched on) all the time? Battery charge is limited to 80% on my smartphone to prolong battery (lithium ion) life. Should I use this for the 2400 and limit the max to 80%? Does the system require the internet to be connected to function properly? I normally switch off the WLAN and router at night to reduce electro smog and save power.
