Hi, I bought the cable to connect my SBV6400 to my HUB1200 because Zendure told me that it works.. (see the answer of Zendure at the end).
I received the cable and … it doesn’t work.. I send a message to Zendure and explain the issue and here the answer:
Dear Customer,
Thank you for your letter.
HUB1200 does not support to use with SBV.HUB2000 only supports to use with SBV.
I hope this reply can help you.
Thank you for your support and understanding.
Best wishes,
Zendure
(Pulling my legs)
And this the First answer from Zendure :
Le 27 août 2024 à 12:14, Marinella B. a écrit :
Hello,
Yes, that's correct. You can purchase the cable to connect your existing SBV (SolarBridge) with the SolarFlow Hub1200, and you don't need to buy a new Hub2000.
Additionally, you can purchase a Hyper2000 and stack it with your existing AB1000 batteries or new AB1000/2000 batteries to expand your energy storage capacity. The Hyper2000 is compatible with the AB series batteries, allowing you to mix and match different battery models to create a customized energy storage system.
Please note that it's essential to ensure compatibility and follow the manufacturer's guidelines for stacking and connecting different battery models to ensure safe and optimal performance.
Further, it is highly recommended to consult a certified/professional solar panel.
Best regard,
The SBV is maybe dangerous indeed I wanted to charge it on AC power (normal use), after a couple of minutes there was an mini explosion, Lightning at the top back right and smelling of burning but they don’t care and no answer about that.
