Dear Users,
We would like to provide you with an update on our future feature enhancements that we hope will be helpful to you:
Zendure APP Feature Updates:
We will release a new version of the APP in early October, which will support the following features:
- Local Communication:
Supports local communication between Hyper 2000 and Shelly Pro 3EM, making the Smart CT mode regulation more stable.
Usage Logic:
When Hyper 2000 and Pro 3EM are connected to the same local network(Wi-Fi), device-to-device communication will be automatically established within 20-30 seconds. Once local communication is established, the Smart CT mode will display the "Connected via Local Wi-Fi" icon, making the operation of the Smart CT mode more stable and not affected by server issues.
Special Note:
This feature requires the latest Hyper 2000 firmware.
- Bypass Mode Update:
Supports Hub 1200、Hub 2000、AIO 2400 entering bypass mode while working in Smart CT mode.
Special Note:
This feature requires the latest firmware for Hub 1200\Hub 2000\AIO 2400. After the firmware update, the bypass setting will automatically be set to "Auto."
Entering bypass mode from Smart CT mode may cause power to flow back into the grid when there is too much sunlight, so please set according to your needs.
Product Adaptation:
We have optimized some SBV image display issues.
Clever-PV Integration:
Clever-PV has integrated our products.
If you want to know more about it, click it: https://www.clever-pv.com/post/neue-integration-balkonkraftwerk-mit-speicher-von-zendure/n/nFirmware Feature Updates:
Smart CT Mode Can Enter Bypass Mode:
We will release new firmware for Hub 1200\Hub 2000\AIO 2400 in early October, which will support devices entering bypass mode while working in intelligent CT mode. We hope you will be satisfied with this update.
Local Control of Hyper 2000 and Pro 3EM:
We will release new firmware for Hyper 2000 in early October, which supports local control with Pro 3EM, providing you with a more stable Smart CT mode experience.
