Micha‘s-PV Frage: können 2 PC gleichzeitig in das selbe Heimnetzwerk integriert werden?? Antwort : Ja 😊😂
🌞⛅🌦️🌧️☁️🌤️☀️ That depends on several factors. Technically, it's certainly possible if your house has adequate electrical protection (fuses). Legally, it depends on how much wattage input is allowed by your country's legislation.
roberto I mean: if I put 2 hub2000 on the same network, which hub works? Even if I have the shelly that define the consumption and I do not put into the network more than what I consume, do the 2 hubs disturb each other?
Felli They will not disturb each other but as far as I know, it's only possible to attach the shelly to one of them. Means the second can then only be run in schedule mode for example. If you want them work together as group it will be better to use the hyper instead.
roberto I can't insert the hyper2000 because in Italy it doesn't have the necessary certification. But I have a hub1200 and an upgrade hub2000.
