MitschyOnAir Hello Could you implement a Feature that we can change the output Power depending on the Batterie load. Example: Batterie load over 80% output 90Watt Batterie load lower 60% output 60 Watt (Like a hysteresis loop)
MitschyOnAir That non sens should, with that Feature small Systems should power 30W to 90 W 24hour out of the Batterie. And should prevent that batter dont get empty and also not full. When Batterie is low output should ne set to 30W. If it's geht's full ober 80/90% Power should go to 90W to prevent 100% load. Because when Batterie is 100 all power output is waste in germany.
